AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present (https://acuralegend.org/index.php)
-   Audio and Other Electronics (https://acuralegend.org/forumdisplay.php?f=28)
-   -   antenna problem (https://acuralegend.org/showthread.php?t=7800)
woosa 12-31-2009 12:15 PM
antenna problem
just got a new antenna and it goes up all nice and neat but when its all the way up it makes a kinda grinding noise for a few seconds. same when it goes down and it doesnt go all the way down. i checked out the gears and everything looks to be fine but it just does not want to go down. any idea what could be happening? got a video for you too.
http://www.youtube.com/watch?v=8Upgb...eature=channel
Quaraxkad 12-31-2009 02:27 PM
Is it one of those $30 universal aftermarket antennas? If it is, that's why. If it's an OEM antenna, is it actually new or used? Pull out the mast and see if the teeth are worn.
bboarder711 12-31-2009 03:04 PM
discconect it and shave it ...
Apex|000 12-31-2009 10:46 PM
+1 to that.
bsmooth1027 01-01-2010 08:46 AM
i have the same problem how do u shave it ???
94LegendaryAcuraGS 01-01-2010 10:39 AM
I replaced the masst with a $30 Ebay unit and solved that problem. It's been perfect for about 3 years now. Shaved would look pretty though!:giggle:
canucks 01-01-2010 02:06 PM
well if you shave it then you need to hook up one of those hidden antennas. I replaced my mast but not the complete assembly and it didn't fix the problem so im looking to find a good hidden antenna now
bboarder711 01-01-2010 02:25 PM
since i listen to my ipod more often then the radio i tend to disconect it in the winter so it doesnt freeze
