Old 10-28-2009, 09:27 PM   #11
samblaze
SGM/Type F
samblaze's Avatar
samblaze is on a distinguished road
Originally Posted by telafonic View Post
Reading your thread title quickly out loud is funny and turns it into something else.
Did you replace the o-rings when you changed the injectors? Look for fuel around them after running the engine.
This is most likely your problem. Were the o-rings lubed when you replaced them? If not one of them might have lost its 'seating'. Run the engine and look for gas overflow towards the top of the injectors, resulting from a bad seal at the o-ring.
94 GS 6MT
Sig by DG
samblaze is offline   Reply With Quote
Old 10-28-2009, 09:37 PM   #12
Outlaw92
The Innovator
Outlaw92's Avatar
Real Name: Ray
Outlaw92 is on a distinguished road
Send a message via Yahoo to Outlaw92
Already did. Smell is coming from the rear. I'm guessing its one of my fuel lines. Or something around there.
Outlaw92 is offline   Reply With Quote
Old 10-28-2009, 09:40 PM   #13
samblaze
SGM/Type F
samblaze's Avatar
No leaks at the filter right?
94 GS 6MT
Sig by DG
Old 10-28-2009, 09:51 PM   #14
No Taco Bell?
No in all seriousness from the rear it could be a bad filler pipe or gas cap. I'd still check your injectors for crud building up on them....while you may not see them leaking, they could only leak periodically and stop once the car warms up and the seals expand...
Old 10-28-2009, 10:12 PM   #15
samblaze
SGM/Type F
samblaze's Avatar
Wait you mean the rear of the car? I was thinking rear of the engine bay hgeez:, From the rear of the cabin it may be a leaking line, rust in the neck/filler pipe, even a bad gas cap. Any fuel leaking onto the ground?
94 GS 6MT
Sig by DG
Old 10-28-2009, 10:17 PM   #16
clogged cat?
if so now would be a good time to buy my full exhaust hint hint
Old 10-28-2009, 11:58 PM   #17
Goatman
Head Ninja
Goatman is on a distinguished road
Send a message via AIM to Goatman Send a message via MSN to Goatman
Umm.. You guys are all missing the most obvious (and might I add, easiest to check) cause for a fuel smell in the cabin.
Is your gas cap on all the way?
I believe in Christianity as I believe that the sun has risen: not only because I see it, but because by it I see everything else.
-C. S. Lewis
Goatman is offline   Reply With Quote
Old 10-29-2009, 12:25 AM   #18
xpressive
Seattleite
xpressive is on a distinguished road
If it's in the cabin, how would the gap cap be the issue?
The top of the tank is under/behind your rear seat. Takes about 15 minutes to have the seat out. I'd poke around there.
1994 Acura Legend LS 3.5 - 284k SOLD. [02/21/2013]
RIP Fut.. Never forgotten.
xpressive is offline   Reply With Quote
Old 10-29-2009, 12:27 AM   #19
OLDSKOOLACURA
legend love
OLDSKOOLACURA's Avatar
fuel pump :dunno:
Old 10-29-2009, 04:41 AM   #20
93lsz
93lsz is on a distinguished road
Originally Posted by alittlethin View Post
Your line going to the fuel pump might be starting to rust through.
Believe he's correct.
Remove the rear driver side wheel, the black plastic cover and check out those fuel lines!
93lsz is offline   Reply With Quote
FS: Cabin Air Filter $5 onthe3rdday OEM Parts 4 08-27-2009 07:05 PM
Location for running a wire into the cabin? FutureX 2001 2nd Gen. Legend General Discussion 16 08-21-2009 12:02 AM
Whats your cars smell? GreekPower The Water Cooler 51 08-17-2009 11:58 PM
Air Conditioning Bad Smell veee 1st Gen. Legend General Discussion 2 07-24-2009 07:39 AM
Gas smell under the hood when hot mad_legend 2nd Gen. Legend General Discussion 10 07-23-2009 12:09 PM
