#11 |
Using the 3/4"clear tube was great! Nice DIY; I didn't have to take off the splash guard.
long 1/2" extension 1/2" socket wrench 17mm socket 3/8" ratchet for the drain plug On my 1994 GS the fill bolt has a 17mm head. Part numbers for the differential washers: fill bolt washer:94109-20000 3/8" drain plug washer: 94109-14000 torque drain plug 29ft.lb torque fill bolt 33ft.lb I was able to get almost 1Qt in; the fill capacity accord to the FSM is 1.1Qt. Recommended oil: Hypoid gear oil API Classification GL4 or GL5 viscosity; SAE 90 above 0*F (-18*C) SAE80 or SAE80 W90 below 0*F (-18*C) Cheers,
====== Let's bite off more than we can chew ... |
#12 |
What the Diff
The washers are not that much. From the Acura dealer in the area, I was able to leave with 5 drain and 5 fill washers under $15. Allegedly, they're still in use for some post-2000 Accord models, which is why their inventory of crush washers is so abundant.
| DIY: Differential Removal | Captain Kenpachi | Second Generation Legend (1991 - 1995) | 11 | 02-07-2019 09:00 PM |
| Differential Fluid ??? | Roger | 2nd Gen. Legend General Discussion | 28 | 05-13-2011 09:07 PM |
| FS: Auto Differential G2 | Russian | OEM Parts | 16 | 09-21-2009 09:09 PM |
| Power steering fluid bubbling? | LegendLand | 2nd Gen. Legend General Discussion | 5 | 06-30-2009 12:18 AM |
| DIY: Manual Transmission Fluid Change | sam o nela | Second Generation Legend (1991 - 1995) | 0 | 06-10-2009 10:45 PM |
