#11 |
why so serious
good point, ok so i changed the oil , ticking got a lil quieter, but not much.its still loud,but now the oil light flickers ,and i reved it a lil and the oil light went out then it comes back on......im thinking of pouring the 1/2qt. of diesel fuel in the engine , hopeing it will clean out a clogged hole...
#12 | |
![]() Quote:
#13 |
why so serious
i was going to try sea foam but i think the diesal fuel is more likely to clean it out better.
#14 |
why so serious
ok so i poured the deisal fuel in and the sedan is idleing (i put a stick to make it idle that high) at 1100 rpm's as i type .i cant drive it around cause it has no tags ,so i will let it idle like that for a good 45 minutes or so.hope fully it takes the ticking away and the oil light will shut off......if it does not then do i have to take the heads out or just the rocker assembly off?
#15 |
why so serious
left it on an hour, but no luck ,still ticking ,guess its a lifter .like i said i had changed the oil two days ago , and when i drained it today after the deisal fuel flush the oil was black as black can be so the deisal fuel cleaned the inside pretty good.....
#16 |
ridin' high
what oil are you using? Since you have already changed the oil, I would recommend a flush such as amsoil engine flush in addition to running 1 quart of ATF in the crankcase. After running this through your motor, drain and replace with fresh fluids. I've heard that lucas oil stabilizer actually does help because it coats the metal parts that cause the ticking. If it is still ticking after the engine flush, I would try adding a bit of lucas in.
. k e n |
#17 | |
![]() Quote:
#18 |
why so serious
no the stupid light didint go out ,im using cheap wal mart oil for now ($9.50) whats amsoil? my plan is to buy the wal mart oil again and lucas
#19 | |
![]() Quote:
You need to clean out your oil orifices and inspect your oil pump. I wouldn't drive it you might spin a bearing
"Where the F.. is the, "SWEET SPOT !!??",... I can't find it?? ![]() Last edited by alittlethin; 10-28-2009 at 08:26 PM. |
#20 |
why so serious
how do i test to see if my oil pump is good
Speed bump - Loud bang/clank - What is it? | AckLeg92 | 2nd Gen. Legend General Discussion | 17 | 10-02-2012 04:06 PM |
Clicking in sterring column | 90LSCoupe | 1st Gen. Legend General Discussion | 17 | 09-09-2009 10:09 AM |
Transmission Clicking? | 89HondaLegend | 1st Gen. Legend General Discussion | 10 | 08-05-2009 05:54 PM |
Clicking Noise wtf? | spcgloc | 2nd Gen. Legend General Discussion | 9 | 07-28-2009 06:54 PM |
Make Money By Clicking On Adds, No Joke. | Acura Brother | The Water Cooler | 47 | 07-15-2009 12:46 PM |
