|  | #11 |
| Sedan Coming Soon Join Date: May 2010 Location: Duluth, Georgia
				 Real Name: Kevin Amoth    |
			Even with Royal Purple in the crankcase, you have doubts in your head just by starting this thread.   If it was me, I'd give my brain some good peace of mind and change it out.
				__________________ 7-1-25 *1994 GS Automatic Sedan 99,925 miles* June 2025 miles driven = 20 (not by me!) |
|  | #12 |
| Senior Member |
			Can anyone tell me why royal purple should last longer than other oils of the same standard? Is there a special additive put in the royal purple or are you just staying loyal to some weird idea put out here? I'm not saying royal purple isn't a good oil, but I find it hard to believe it last that much longer than other oils of the same type or standard.
|  | #13 |
| Member Join Date: Jun 2009 Location: Houston, TX
				 Real Name: Wayne  |
			Todays oils are much more resilient then oil 10-15 years ago. Both 6-speeds may see 300-500 miles a year. They get started regularly and moved around. I change the oil in them once a year. The automatic (daily driver) is changed every 3000 miles; about 6 months. I tend to go through batteries, I buy the high end batteries and exchange them every 2 or three years when they go bad. WW-
				__________________ '12 GMC Sierra SLT Crew Cab, '02 Lexus SC430 '94 LS 6-Speed Coupe, '94 GS 6-Speed '95 GS Automatic (Formally lukin3) '72 Buick Skylark Convert, Frame Off Resto |
|  | #14 |
| Senior Member Join Date: Jun 2009 Location: SoCal
			Thanks guys.  All great info and I appreciate your input.   Advice is duly noted and I'll find some time to work on it asap.
|  | #15 |
| Just some guy Join Date: Oct 2009 Location: Seattle
			These questions seem to be popping back up again. There was a guy on BITOG (Bob is the oil guy) a couple of years ago that had a motorcycle with 15 year old oil. He drained the oil and sent the 15 year old oil in for analysis. Everyone expected the worst. He lived in a dry climate. The bike was stored indoors the whole time and not started. The oil had a few thousand miles on it. The UOA came back showing the oil in perfect condition; no condensation, nor acidic conditions and a TBN (total base number) well within normal range. If my car were in Tyson's garage where it's a relatively consistent temperature and low humidity It would not bother me to leave the oil in the motor for five years if I was only putting a couple of hundred miles a year on the car. The oil is made to deal with acidic condensation. If you are going to start the car during long storage periods then start it and drive it for at least 30 minutes. Simply starting it and letting it idle in the driveway is the worst thing you can do for the car. 80% of all engine wear takes place during startup and warmup. When you start the car you draw 150 amps with the starter and take the surface charge off the battery. It takes time to replenish the battery. As you know throwing 80 amps at it from the alternator does not provide the time to adequately saturate the plates. I have watched the charge profile on the manual charger here at home. A battery needs at least an hour of charging to completely recover from a single start cycle. There is a thread in the G1 section talking about dying batteries in a sitting car. The guy wants to go out and periodically start the car to keep the battery charged. The better answers are to either buy a battery tender or disconnect the battery. Two weeks is enough time for the battery to discharge enough that the plates start to sulfate and decrease charge capacity. I believe we can solve two problems, oil and batteries by not starting the cars periodically believing we are doing them good. Next is to invest $45 in a battery tender or disconnecting the battery. I really like the battery tender. It charges the battery up to ~14.5 volts and then floats the battery around 13.2 volts. Those are great numbers. Your battery will always be topped up and there won't be a long inrush of high current right after startup. Dave Last edited by DrDave; 06-12-2011 at 09:17 AM. |
|  | #16 | |
| legend love Join Date: Aug 2009 Location: hell if I know
			^so should I just stop starting it up until it's back on the road?
				__________________  Quote:
|  | #17 |
| Low mileage nutso Join Date: Jun 2009 Location: central NJ
			As Dr Dave was eluding to, 2 years should be fine- esp if it is Synthetic but I would change it.  I dont drive my coupes much- maybe upwards of 1500 miles a year and use Mobil 1.  When I sent a sample in to Blackstone after 1 yr they said the oil was fine and to extend the changes to 18 months or more.  However, I do try not to let the cars sit for more than two weeks at a time.  And I hardly ever start them and not take them for at least a 20min drive.  I usually try to get them on the highway for a bit
|  Similar Threads | ||||
| Can old plug wires cause a low idle? (NGK, 3 yrs, 64,000 miles on plug wires | Fred Clark | 1st Gen. Legend General Discussion | 7 | 12-16-2010 12:04 AM |
| Oreilleys has a great deal on Royal Purple Oil Change + K&N oil filter right now. | Reboticon | 2nd Gen. Legend General Discussion | 16 | 07-02-2010 10:54 AM |
| G1 on its original oil change! | LtownLegend | "Not Mine" | 14 | 01-02-2010 10:34 PM |
| 60k without a oil change | czechboy | The Water Cooler | 37 | 12-04-2009 12:05 PM |
