Old 12-30-2010, 07:15 PM   #31
LOL I really didn't know if it was a serious question or if people were adding to the sarcasm. My response was serious in case anyone really didn't get it. Carry on
Old 01-07-2011, 03:19 PM   #32
Originally Posted by Vic Cardenas View Post
You're right, it seems 3.9 liters is possible with our engines.
Science of Speed has a stroker kit for the NSX to go up to 3.8 liters.
That kit is 95mm bore X 88mm stroke
So, if the piston spacing is the same as the NSX like Matt says, then we should be able to get 95mm bore too. C35 has a 91 mm stroke so that calculates to 3870.167 Cubic Centimeters or 236.080 cubic inches.
So, who will be the first to stick 95mm pistons in their Legend?
I did look into it very briefly when i was contemplating a 3.5L swap or to stick with a 3.2L (i stuck with the 3.2L and did major servicing)
Pricing would be astronomically high in G2 Legend terms (well that's relative since most of my customers wouldn't be bothered with that )
the custom sleeves won't be cheap the pistons alone will set you 700-900$
If you'd need a custom crank to stroke it - $1250-2000, Connecting rods for the custom crank $600-800
Those prices would be US prices for europe add 50-70%
Then you'd also run in to intake problems since a 3.2L IM is not designed for 3.9L so factor those costs in as well,
I think your getting my point it ain't cheap although personally i say it's partially worth it.
But factory cost in to a sort of chart of ultimate or worth while mods it isn't going to rank above a RWD or AWD conversion.
Old 01-08-2011, 05:06 PM   #33
Vic Cardenas
Vic Cardenas's Avatar
I never said it was going to be cheap. Sleeves and pistons will set you back more than $2000. Most people would say an All Motor build will cost more than F/I and net you less power. I agree with that. But there are plenty of pros, and with F/I there are plenty of cons.
Also, you touched on stroking in your post. (that sounded dirty ) I never mentioned stroking the Legend but was making a comparison to the NSX stroker kit from SOS. I think the OEM stroke of 91mm on the C35 is plenty and piston speeds are already high enough. I'm skeptical that the C35 could even be stroked at all. I think a bore and stoke of 93-95mm X 91mm sounds great and would make a very powerful engine without a stroker kit. No need to stroke unless you just want it square. Oversquare sounds fine to me.
You made a great point about the intake. Most people that do an All Motor build would add ITB's and a significant port and polish. That would be great and all but is more uncharted, expensive territory. Perhaps the NSX ITB's would fit? If I were to do this type of build, I would start out with a P&P and use a type II intake manifold. I think the type II IM may work.
AutoAlchemist.com
Old 01-08-2011, 05:17 PM   #34
Car2n
R.I.P. FUT
Car2n's Avatar
Car2n is on a distinguished road
Re-sleeving for the NSX block is around the 1500.00, and the NSX TB I know fits the G1 intake manifold it might fit the G2.
Real Legend enthusiast... a Legend Pioneer member... R.I.P. fellow friend and Legend lover FUT
Car2n is offline   Reply With Quote
C32 and C35 functionally Interchangeable parts Telion 2nd Gen. Legend General Discussion 3 10-25-2009 05:31 PM
04+ TL Rims Bored/non-bored Ackrite OEM Parts 0 10-09-2009 10:55 AM
If anyone wants to be bored... GreekPower The Water Cooler 34 09-24-2009 01:05 PM
Possible engine swap-c35 best bet? squriellord 2nd Gen. Legend Performance Enhancements 8 07-21-2009 07:28 PM
