Old 03-24-2010, 11:44 PM   #1
18 characters long
SquareBobPantsSponge
18 characters long's Avatar
Real Name: Dawson
Default Brake MC.
Mine apparently died tonight. No fluid loss, all brakes working, but the pedal is dead until about ½-¾ the way down. I pulled into a gas station, got gas, paid for it, and came out, brakes were fine pulling in, as I pulled out though, I went to stop, pedal dropped, I panicked, and locked them up. Pulled back up to the store, checked everything, there was no fluid loss from any of the reservoirs, or calipers, all the lines are fine, and all the calipers seem to be working fine. I have brakes, but instead of having half a pedal of travel from just dragging to locked, I have about a fourth. It's exactly what my friend's Topaz did when his MC went out, only his went out over 4 months, mine went out over 4 minutes.
I know for whatever stupid reason the MCs are ALB and non ALB, but why? Why can't I use the one from the '87?
I'll probably grab the one at the junk yard on Friday, there's a Melbourne Blue '90 LS there. I've got to go grab a couple sensors, auto climate motor, and some other little doodads. (lol@ doodads not triggering spell check)
Is there any way to check a MC to be good or not without fluid? The junk yard empties all the fluids out of the cars.
Fut
Old 03-24-2010, 11:57 PM   #2
Sucks, same shit happened to me when the MC gave up on me. The only way I knew it went out was because fluid started leaking on the back side where it mounts to the booster and the booster had fluid fluid on it l, which ended up eating the paint off of it.
Old 03-24-2010, 11:58 PM   #3
Car2n
R.I.P. FUT
Car2n's Avatar
Car2n is on a distinguished road
Why not to get a new MC? I believe they are not very expensive, on brakes is always to get new parts but if is not possible then used one is fine. I have a used one you can have but wonder what is cheaper the junk yard one or shipping from ELP to you.
Real Legend enthusiast... a Legend Pioneer member... R.I.P. fellow friend and Legend lover FUT
Car2n is offline   Reply With Quote
Old 03-25-2010, 12:14 AM   #4
18 characters long
Real Name: Dawson
Well if it's an ALB MC. But it's only $10 at the junk yard. And $67 new. So, it's quite a lot cheaper used.
Fut
Old 03-25-2010, 07:23 AM   #5
Ya it's cheaper, but you won't know how long it'll last.
Old 03-25-2010, 09:27 PM   #6
^ Input (hole) opening differs from the non anti-lock MC D ...you'd have a fun time trying to make a good seal, to a point where you compromise the hydraulic fluid line; that would still leak!
Old 03-26-2010, 05:10 AM   #7
cakes
The Dream
cakes's Avatar
how long are MC's supposed to last anyways?
Better hope the one you're grabbing from the JY isn't the Original, because its probably on its last leg.
Old 03-26-2010, 08:21 AM   #8
The answer to that question is probably largely contingent on the maintenance of the braking system itself...especially the fluid.
Old 03-26-2010, 12:31 PM   #9
18 characters long
Real Name: Dawson
Well after buying the one at the junk yard, I came home, popped the hood, and noticed a pin on the floorboard. It was for the brake. I apparently put them in backwards, had the clutch pin in the brake, and the brake pin in the clutch. The brake pin is shorter, and the colder pin won't go in it. So I switched them, put in colder pins, and everything is back to normal. Now I just have to go get my $10 credit. lol
Fut
Old 03-26-2010, 12:36 PM   #10
tubadude
Frankenlegend lives!
tubadude's Avatar
Real Name: joe mama
tubadude will become famous soon enoughtubadude will become famous soon enough
Send a message via AIM to tubadude Send a message via MSN to tubadude Send a message via Yahoo to tubadude
use it to buy a box for my stuff!
Originally Posted by mad_legend
Now Dammit! I'm dying to shit my penis! lol
tubadude is offline   Reply With Quote
e brake robertstrendell 2nd Gen. Legend General Discussion 4 02-23-2010 09:36 AM
still having brake problems bunnyhop1 1st Gen. Legend General Discussion 6 02-03-2010 05:33 PM
Brake Problem midwest2 1st Gen. RL General Discussion 5 01-05-2010 02:11 PM
Brake questions Goatman 1st Gen. Legend General Discussion 9 09-01-2009 12:21 AM
No Brake Lights hard2qill 2nd Gen. Legend General Discussion 0 08-23-2009 05:44 AM
