Old 06-17-2010, 03:31 PM   #1
MrPeacock72
MasterProcrastinator
MrPeacock72's Avatar
Real Name: Daryll Peacock
MrPeacock72 will become famous soon enough
Send a message via AIM to MrPeacock72 Send a message via Yahoo to MrPeacock72
Default I Was Bored Yesterday...
... so I made a pair of PnP USDM>JDM harnesses for headlights that I don't own yet. The majority of this stuff (relays, loom, heat shrink, solder and iron, etc.) is already in my possession. I had a broken set of USDMs that I wasn't using, so I went Orielly's and picked up a pair of JDM harnesses and got to work. SUPER easy if you've wired JDMs before.
Antenna Relay Solution
MrPeacock72 is offline   Reply With Quote
Old 06-17-2010, 03:35 PM   #2
Geneva_Jee
Gold Member
Geneva_Jee's Avatar
wow nice work
great way to turn spare time into something constructive
Old 06-17-2010, 03:41 PM   #3
MrPeacock72
Originally Posted by Geneva_Jee View Post
wow nice work
Thanks. It actually motivated me to go ahead and start looking for some JDMs. I may have some by next week.
Old 06-17-2010, 03:45 PM   #4
Geneva_Jee
Gold Member
Geneva_Jee's Avatar
good job dude, I'm hoping to get some jdm's soon too
GL with your search
Old 06-17-2010, 03:51 PM   #5
Nice work Daryll! They turned out really clean. these are incredibly easy to make with just a couple parts and as long as you know the wiring layout. Nice job man.
Old 06-17-2010, 09:14 PM   #6
MrPeacock72
I can't wait until I score me some headlights so I can install them.
Old 06-17-2010, 09:26 PM   #7
sdgayoon
sdgayoon's Avatar
Real Name: K.J
sdgayoon is on a distinguished road
Do you mean the harness for JDM one-piece headlight?
Actually, it doesn't need relay if you are to use h4h bulb for JDM headlight.
sdgayoon is offline   Reply With Quote
Old 06-17-2010, 09:44 PM   #8
MrPeacock72
This is the reason why I've ran relays in the past and this time: JDM headlight wiring
The problem with the [USDM] stock setup is that the high beam wire is always hot unless it is properly grounded which runs through a relay.
Old 06-17-2010, 09:46 PM   #9
Wow great job man that looks great!
Old 06-17-2010, 09:54 PM   #10
sdgayoon
sdgayoon's Avatar
Real Name: K.J
I looked over them you had linked.
I'll post soon wiring diagram for JDM one-piece head light without running relay.
copped somthin nice yesterday. reddLegend Audio and Other Electronics 3 02-10-2010 09:37 AM
Excellent trip until yesterday..... Jet Wrench 2nd Gen. Legend General Discussion 4 12-05-2009 07:35 AM
04+ TL Rims Bored/non-bored Ackrite OEM Parts 0 10-09-2009 10:55 AM
So, I got rear-ended yesterday, how about you? DreamPCs 2nd Gen. Legend General Discussion 9 07-20-2009 01:33 AM
