Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > General DIY Discussions > Wheels & Tires
Old 01-03-2014, 09:10 PM   #1
Aking
Aking's Avatar
Real Name: A King!
Default Wheel spacers
Anyone used them? Was going to put a set of 19s I have here on my legend but I would need these 1.25" spacers. Anyone ever used them?
Old 01-08-2014, 05:55 AM   #2
91BlackSmoke
91BlackSmoke's Avatar
91BlackSmoke will become famous soon enough
Please do not use the spaceres unless you install extended lug nuts. I personally would not use anythimg larger than a 5mm spacer. And even that is shakey. Had the 5mm spacer on my sc400 to help the sc430 wheels clear my bbk. The wheels would come loose all the time. Lugs would need re tightenimg every couple hundred miles. Needless to say i dont use the wheels or spacers anymore. It just did not feel safe.
-james
91BlackSmoke
91BlackSmoke is offline   Reply With Quote
Old 01-09-2014, 05:11 AM   #3
Aking
Aking's Avatar
Real Name: A King!
Actually I am incorrect in terminology I should have said whelk adapters to convert a bolt pattern. Only thing is these things are like 1.25" thick! My wheels will probably have a crazy offset.
Old 01-10-2014, 03:49 AM   #4
91BlackSmoke
What bolt pattern? There may be altenatives.... the wheel adapters are frowned apon and are a big no no in my book. If the wheels are 5x112 you can ise wobble nits which is what i use for my german wheel applications on my japenesse cars. Works great. And no issues. Just be sure to torque to specs and uour good to go.
-james
91BlackSmoke
Old 01-10-2014, 05:28 AM   #5
Aking
Aking's Avatar
Real Name: A King!
-james
The other bolt pattern (German) is 5x120.
Old 01-10-2014, 03:54 PM   #6
91BlackSmoke
The 5x120 is a no go for the wobble nuts. The spacer/adapter would be your only option that i know of. Everyone I've ever inquired with about redrilling 5x120 to 5x114.3 have said it cannot be done.
The really crazy and expensive way to get them to fit would be to change your hubs to a 5x120 bolt setup. Possible but more of a permanent mod.
I love those bimmer wheels bit we just cant make it happen. I know the lexus guys are big on puttin the 745 wheels on the gs' and are accomplishing this with the adaptors you are speaking of. But they can pull off those crazy low offsets that are usually found on the bmw wheels and still have room for the adaptors width.
The issue with the Legend is the lowest off sets we can pull off are +35 without serious modifacation. And even that will require a fender roll in the rear and some negative camber up front. And to add, ive only experimented up to a 8.5 wide wheel not sure how much wider you could go without scraping on the inside.
-james
91BlackSmoke
Old 01-10-2014, 09:05 PM   #7
Aking
Aking's Avatar
Real Name: A King!
-james
Thanks for the feedback man.
H&R Wheel Spacers to eliminate hub boring FrostCoupe Group Buys 21 05-04-2012 08:05 PM
wheel spacers derajnampahc 2nd Gen. Legend Performance Enhancements 9 09-08-2011 05:04 PM
FS: Two Manual Spacers The Crowing Non-OEM Parts 2 05-15-2011 10:52 PM
injector spacers DSL 2nd Gen. Legend General Discussion 26 01-22-2010 06:13 PM
Wheel Spacers?? Roger 2nd Gen. Legend General Discussion 11 07-20-2009 08:44 PM
