Old 08-14-2009, 07:56 PM   #1
forevralegend
3.2 FTW
forevralegend's Avatar
Real Name: Eric
forevralegend is on a distinguished road
Default Cruise Problem after 6spd swap
I just tried the cruise control on brynosaurs car and its not working. It was working fine before the swap. The main cruise light will come on but not the one in the gauge cluster. The cruise is just unresponsive. At the auto shifter harness I connected the pink wire to ground, this is what everyone has been saying works however it doesn't.. Anyone have any ideas?
custom 2.5" mandrel bent exhaust, CAI,web cams, p&p heads, tb bypass,egr block, 5spd clutch/fly, poly 80a mounts, type 1 crank pulley, Premium OBX headers, custom y-pipe, SR5guy Chip, 6spd trans, prelude strut bar, Addco sway bars, custom tie bars, ksports
243.3 hp 197.7 ftlb N/A dynapack 232.8 hp 204.0 ftlb N/A dynojet 10/19/07
13.657 1/4 mile @ 101.861 mph & 1.934 60' NA
forevralegend is offline   Reply With Quote
Old 08-14-2009, 08:14 PM   #2
The pink wire is supposed to go to the clutch switch in an MT. I don't know how this changes when you swap from AT to MT, so I don't know if that's of any use to you.
Old 08-14-2009, 08:19 PM   #3
forevralegend
3.2 FTW
Real Name: Eric
yea that is how I have it wired up, it goes to the switch and then to ground. So any time the clutch is not pressed the pink wire is grounded. There is something else besides the wiring at the shift harness that needs to be done to get cruise to work but i have no idea what it is. Do you guys think the cruise control computers are different for manual vs auto? Thanks for the suggestion Quaraxkad
Old 08-14-2009, 09:06 PM   #4
The cruise control units for the 4AT and 6MT GS of the same year do have different part numbers.
AT: 36700-SP0-A51
MT: 36700-SP0-A41
Old 08-14-2009, 09:13 PM   #5
sap
ignore the smoke
sap's Avatar
Send a message via AIM to sap
Alex was telling me before about getting his cruise control wired up. I don't remember the details, but it can be done. I assume he'll chime in here at some point.
Sig by Cole Austin
RIP Fut RIP l4zy
Old 08-15-2009, 12:14 PM   #6
forevralegend
3.2 FTW
Real Name: Eric
AT: 36700-SP0-A51
MT: 36700-SP0-A41
hmmm now thats interesting... If they were just wired differently then they would be the same part numbers. Thanks Quaraxkad
I need some input on this from someone who tested the cruise control after the swap and it worked perfectly no assumptions.
Old 08-15-2009, 05:12 PM   #7
Reboticon
Lord Of The Clunker
Reboticon's Avatar
I can tell you with 100% certainty a civic will not have working cruise control after swapping to manual from auto. The cruise control units are different. Seems Alex may know a way to make it work, but im gonna bet it involves swapping in a manual cruise unit.
Old 08-15-2009, 05:20 PM   #8
okay. if the pink wire, has a good ground. make sure the brake switch works.
Old 08-15-2009, 07:15 PM   #9
forevralegend
3.2 FTW
Real Name: Eric
brake switch works, the pink wire is definitely grounded properly
Old 08-15-2009, 07:43 PM   #10
just trying to go over the basics, of the system. the clockspring is good right? what about the neutral switch?
My 94 6spd kcf Second Gen Legend Gallery -- 1991 - 1995 23 09-06-2009 03:44 PM
Cluster Buttons (SUNROOF AND CRUISE CONTROL) BklynSoulja OEM Parts 5 07-28-2009 08:34 PM
Cruise Control Delete GreekPower 2nd Gen. Legend General Discussion 34 07-07-2009 11:44 PM
SoCal Crestline Cruise... 07/27/08 kotetu Meet Photos 0 06-27-2009 09:55 AM
