|  | #1 |
| Member Join Date: Apr 2013 Location: California
			Over the past year, my engine has cut off 4 times while running. Twice while parked and idling. Once during initial take off from a stop sign. Then today, after hitting a big bump driving around 30 mph. Each time the car started right back up with no issues whatsoever. Restarting right away makes me think it isn’t fuel pump. Right? I replaced the main relay with a brand new OEM one about 1.5 years ago. Fuel filter replaced about 3 months ago. Maybe the ignition switch? Thanks for the advice. |
|  | #2 |
| The Mad Scientist!! Join Date: Jul 2009 Location: Inside the LAB!! ;-) Near Magic City Alabama
				 Real Name: DUH The Mad Scientist!! A.K.A. Chaka    |  I really have no idea on this one but shall watch curiously for others to input.  The fact you replaced the main relay covers the only "possible idea" I had initially. Cracked joints in those could possible separate in a good jolt and then make contact again. Its very "interesting" how that main relay is basically a "red light", "green light" for telling the fuel pump on or off. When they're operating properly its a fantastic thing and when they aren't they turn what was originally a $40 - $45 luxury flagship automobile into basically a HUGE PAPERWEIGHT!
				__________________  3.5 Type II Hybrid Club Member!  The Mad Scientist!!  |
|  | #3 |
			Quiet here. Just visited with a local mechanic friend of mine. He thinks my key chain is too heavy, and that, coupled with a weak ignition switch is causing the issue. I stripped down to just the Legend key and fob. We’ll see. |
|  | #4 |
| Senior Member |
			might be a weak main relay? easy to check  just look in this forum for "Main Relay"
|  | #5 |
| Juicey Join Date: Jun 2009 Location: Canada
			Definitely switch or main relay. Even after replacing my main relay it sometimes acts up like the plug isn't very snug and I have to grab it to turn the car over and it has exhibited nearly cutting out in motion.
|  | #6 |
| Ken Join Date: Jun 2009
			This happened to me a few times years ago. My car would stall when slowing to a stop, probably when the auto transmission changed down from 4th to 3rd. It was sludge in the throttle body. Remove the intake breather tube at the throttle body and wipe it clean with a towel. That's it.
				__________________ |
|  Similar Threads | ||||
| Cuts off while driving...no codes... | ellisjay2 | 2nd Gen. Legend General Discussion | 6 | 07-23-2020 10:05 PM |
| Running hotter with new engine. | "L" | 1st Gen. Legend General Discussion | 36 | 08-20-2012 07:01 PM |
| Car intermittently cuts off engine power | LegendaryOG | 2nd Gen. Legend General Discussion | 18 | 02-10-2012 09:09 AM |
| KA8 Sarona fender knock-offs - $120!!! | whats77inaname | 2nd Gen. Legend General Discussion | 120 | 05-27-2010 09:55 AM |
| Engine running cold?? | kcf | 2nd Gen. Legend General Discussion | 10 | 09-07-2009 03:31 PM |
