Old 09-08-2009, 06:39 PM   #1
90LSCoupe
A.K.A. Fallenanjl
90LSCoupe's Avatar
90LSCoupe is on a distinguished road
Send a message via Yahoo to 90LSCoupe
Default Clicking in sterring column
I had taken apart the cover for the sterring column to replace the ingition switch and now i have a clicking/rubbing noise when i turn the wheel either diraction.Would removeing the cover and reinstalling it help or did i just fuck it up some how?
Sig by SickSON71
Squirrels.......natures little speed bumps
Originally Posted by Nino418 View Post
what the fuck is that in your turn signal hole? an led flashlight or something? stupid ricer...
90LSCoupe is offline   Reply With Quote
Old 09-08-2009, 07:07 PM   #2
It sounds like a wire was not tucked in properly during reassembly...
Old 09-08-2009, 07:59 PM   #3
90LSCoupe
A.K.A. Fallenanjl
90LSCoupe's Avatar
K ill check it tomorrow.Also i get a system check light and my info center says to check engine oil level.But its full how hard is it to replace that sensor and where can i get one?
Sig by SickSON71
Old 09-08-2009, 08:07 PM   #4
I believe the sensor is inside the oil pan.
Old 09-08-2009, 08:21 PM   #5
90LSCoupe
A.K.A. Fallenanjl
90LSCoupe's Avatar
yes the one thats right next to the a/c compressor
Sig by SickSON71
Old 09-08-2009, 08:35 PM   #6
Mikeo
1989 Acura Legend
Mikeo's Avatar
Real Name: Mike
Well i got the same thing i just get over it lol
Old 09-08-2009, 08:46 PM   #7
Originally Posted by l4zy415
^ I believe the sensor is inside the oil pan.
As far as the sensor location, James got it right!
That would be the lead wire; which connects to the sensor, at the bottom of the engine block, inside the oil pan!
I'd strongly suggest cleaning the (ground) contacts and see what happens... this apply to you too Mike
Old 09-08-2009, 08:51 PM   #8
Old 09-08-2009, 08:52 PM   #9
90LSCoupe
A.K.A. Fallenanjl
90LSCoupe's Avatar
ok i know of the one ground in the front attached to the side head plate. are there ne more to the motor?
Sig by SickSON71
Old 09-08-2009, 08:55 PM   #10
Nope, there's basically 2 grounds in the engine bay, the one you just explained, and the other one that goes to the tranny.
Anyone know how to drop the steering column? 94legendcpe 2nd Gen. Legend General Discussion 4 09-03-2009 11:34 PM
Transmission Clicking? 89HondaLegend 1st Gen. Legend General Discussion 10 08-05-2009 05:54 PM
Clicking Noise wtf? spcgloc 2nd Gen. Legend General Discussion 9 07-28-2009 06:54 PM
Make Money By Clicking On Adds, No Joke. Acura Brother The Water Cooler 47 07-15-2009 12:46 PM
Last post column smokinfastlegend Feedback and Requests 2 06-08-2009 07:53 PM
